Antec 1200 Cable Management
15 Jul 2010
Hey Peeps!
With an Antec1200 and a Corsair 650w TX, will I be needing cable extensions to be able to tidy the cables on the hidden side panel?
I'd say you should at least get a 4/8pin extender as I need on for my 902 for proper routing.
I didn't need them, but I put my 8pin behind my gfx card (fits very snug and looks very neat :)), if you want to put it through the rear side panel then an extender is probably needed,
The rest you don't need any extenders for, I have the same case and psu :)
