Hi guys I am looking for 2 fans for my Antec 1200 case, One is a 120mm Sidepanel fan bracket and the other is a 140mm VGA duct/Fitted on the HDD cage's as a option fan. So i been doing my searching and looking round and came across these three fans
http://www.scythe-eu.com/en/products...stable-vr.html
http://www.scythe-eu.com/en/products...djustable.html
http://www.prolimatech.com/en/produc...id=1200&page=1
Now I have the Z77 sabertooth board and hoping to hook them up to it as it has a built in fan controller so was thinking if these would be any good, I also have filters on the side and on the HDD Cage's of the VGA/duct with antec's fan that came with case.
AH forgot to add the Dba's anything up to 37.0 would do as sound isnt much a of problem as i have my back to the tower but i looking for something that takes are in through the side and something can blow up to 1 meter for the Vga/duct cage so it blows the air the full lenght of my card as i prefer air cooling to water.
P.S i typed this all in a hurray, I not 110% sure if the sabbertooth does have fan control as such or not sure what you call it.
Would any of of the 3 be any good for what i need or do you recommend something better??
Also would any of these have an affect on my Sound card, the sound card i got fataily Champion series.
