Antec 1200 Problem
10 Aug 2010
Nottingham
The top fan has decided to act up, keeps spinning up and slowing down kinda like a revving car or something.
Looking for a replacement fan if anyone has any ideas what will fit not just in size but dimensions. i think its 200mm and it also has a speed controller if thats going to cause problems with replacement
thanks, also got a question about the speed controlled 120s i'm looking to replace those too, this might be a noob question but do i absolutly have to get speed controlled replacements or can i use any 120mm and if i can what do you guys recommend as the best, price not an issue noise only slightly an issue.
You can use any 120mm fan although if you do wish to slow them or speed them up as desired you'll need to use a fan controller.
yeah i unscrewed the controller unit on the back and realised that it isn't connected and is only clipped on, derp lol.
