Antec 900 build problem
23 Jun 2007
Hi guys i bought an antec 900 case to replace my old one.
Built it today press the power button i heard little squeek from my psu then nothing any ideas kept trying the button every few times i hear the squeek.
Any ideas i really never had any problems with my old build.
Im pretty sure its not the psu but am open to ideas
Again im pretty sure all the cables are in fine.
Thanks a lot Pat
Check you have not shorted any parts of the motherboard on the case, make sure all power cables are correctly fitted.
If that fails you might need to remove the board from the case and check externaly.
