techmob said:i want this case, overclockers said they might have stock of PC7+II case which is of the same specification as the Scandanavian edition.
i guess this case above is the scandanavian edition - hence the SE in the product title? ( Lian Li PC-7 SE-B II )
No - I'm afraid that one is WAAAAY out of your budget - it's an AquaComputer Ready2Go watercooled one. The Aquaero controller alone is the thick end of £100, plus the Bayres, plus the 120.2 RAD and the grille - you're looking at about £340 for that case as pictured.
SE stands for Second Edition and it basically means it has 2 120mm fans. The 'II' designation means it also has a side panel pre-drilled over the graphics cards so it will accept the Lian Li 'Patent Cooling Kit' which is basically a sideways fan. OcUK will not guarantee what you will get when you open the box, so if you need something particular then I would suggest you spend a couple of quid extra elsewhere where they will guarantee a particular specification.
