right guys i have antec 902 with True heatsink the thing is that due to the Tru i cant fit in a fan on the side window... are there any slim fans?? that i can buy to mount in that spot on the window as i would like to add a few more intake fans...
earlier on today while i had the case open i was temped to do a noob job and mount a 120mm fan on the outside of the case on the window to blow air in lol but in end i didnt...
also i have seen people who have 3 intake fans at the front??? how did they manage this and where did the mount the cd drive as i would like to add 3 fans at the front like the 1200... currently i have 2 intake fans at front one exit at back and large exit fan at top...
[edit] the other thing i noticed is that the 295GTX dumps most of the heat inside the case the back plate hardly any air comes out of there... also with the gainward 295 u get a tool called Expert tool in the temp setting it has contols for the fans i always kept the settings on dynamic but when i game the fans hardly turn on and card temp goes to around 80 84oc is this normal or should i crank up the fans manually to 100% via its fixed speed setting???
thanks
thanks
