- 20 Oct 2002
- Derby
Has anyone tried this? The top of the case states it can fit 3x140MM fans but only a 360MM rad is supported, i believe this is because of the different sizes in end tanks/fittings on rads.. The P20CE says the same support at the front but i manage to fit a 420MM Arctic Freezer 3 AIO at the front "just".
Any help would be appreciated. If anyone has the case could you please measure the distance internally from front to back at the top of the chassis?
