Antec FLUX PRO case (lots of design/feature info in the post)
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Hi guys.
The FLUX PRO case from Antec is coming soon, October 2024.
Coming in both black and white versions. The black has a dark wood.
Check it out.
Oh, missed seeing this. And right timing too. My secondary rig is soon getting it's upgrade (especially given the lacklustre release of Ryzen 9000 series and the X870E chipset motherboards) and was looking back towards the Antec One (which wasn't released back when my first rig was upgraded) and I see this here coming up for release for around when the upgrade happens. Nice!
It's actually quite similar to the case I got for my main rig the Lancool III, but slightly more accessible with the top able to come off and the bottom being vented too. The PSU orientation option is also interesting, although I'll probably end up using the PSU with the normal orientation when it all comes together (depends on PSU when I get it). The only thing is, that RGB (and) Fan Controller is going to be wasted in my case, as the fans are going to be replaced with a full suite of Noctua G2's (which has no RGB) and an older Aqua Quadro controller. :D
I know this thread is about the Pro, but given I had the non Pro Flux drop by on Sunday I just want to mention that if your PSU (with cables attached) is longer than the provided max length on the Flux web page, that you can actually remove the drive cage in the lower section of the case to permit a longer PSU to fit in. It is actually only held down by two screws, so it can be reattached later down the line if you need to as well.
