- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
Hey guys,
There has not been much in the way of awareness from Antec regarding these new PSU's. Antec is one of the best manufactured power supply brands out there. They are better than Corsair/BeQuiet & even Enermax. They have excellent technology, and provides some of the best power safety features and output the most stable power for any home or business PC.
Antec have now released a new range called the High Current Gamer.
These are excellent products with all the usual safety/reliability features that you can expect from Antec!
Here they are (single railed units):- (I have promoted the 400w/520w/620w on This Week Only!)
Antec High Current Gamer 400W Power Supply @ £46.99 inc VAT
Antec’s High Current power supplies are the perfect PSU combination of power and efficiency. The
High Current Gamer features a high-power +12V rail and special heavy-duty High Current connectors
and cabling that supply extreme levels of power, and also superb efficiency thanks to 80 PLUS® Bronze certification and Active PFC. Highest-quality gold-plated connectors, Japanese-brand capacitors and quiet 135 mm double ball bearing fans complete the package. If loads of power, High Current engineering and extreme efficiency are what you’re after, the High Current Gamer is the PSU for you.
- 80 PLUS® Bronze certified – up to 88% efficient
- High Current +12V rail for graphics card compatibility and over
current protection (OCP) for safety
- Quiet 135 mm double ball bearing cooling fan
- All Japanese brand capacitors for reliability
- Gold-plated High Current terminals for optimal conductivity
- ATX12V version 2.3 and EPS12V version 2.91 compliant
- Full industrial-grade protection:
- Over current protection (OCP), Over voltage protection (OVP), Short circuit protection (SCP), Over power protection (OPP)
- Active PFC with PF: 0.99 – less harmonic pollution and more
savings on corporate electrical bills
- MTBF: 100,000 hours
- Meets 2010 EUP requirement: 5Vsb < 1W
- Safety: cUL, TÜV, CE, CB, FCC, C-TICK, CCC, BSMI, Gost-R
- Weight: 4.4 lb / 2 kg
- Dimensions: 86 mm (H) x 150 mm (W) x 160 mm (D)
Only £46.99 inc VAT.
ORDER NOW
Antec High Current Gamer 520W Power Supply @ £56.99 inc VAT
Only £56.99 inc VAT.
ORDER NOW
Antec High Current Gamer 620W Power Supply @ £68.99 inc VAT
Only £68.99 inc VAT.
ORDER NOW
There is also the Quad Railed, higher output models which are still on pre-order, these offer the same amazing quality for higher end systems. If I was buying a new gaming system I would use one of these units, they are so much better than other brands due to the technology used inside.
Antec High Current Gamer 750W Quad Rail Power Supply @ £97.99 inc VAT
Making quad rail power and highly advanced power supply design available at a popular wattage, the HCG-750 features special High Current connectors and heavy-duty cabling, earning it NVIDIA® SLI®-Ready and ATI™ CrossFire™ certifications. At the same time the HCG-750 is also 80 PLUS® Bronze certified for efficiency, and features active PFC with a swift, quiet 135 mm double ball bearing fan so you know you're getting not only High Current, but also high efficiency and excellent cooling. If loads of power, High Current engineering and exceptional efficiency are what you're after, the HCG-750 is the perfect PSU for you.
- 750 watts of Continuous Power
- NVIDIA&® SLI®-Ready certified, ATI CrossFire™ certified
- 80 PLUS® Bronze certified - up to 88% efficienct
- Quad High Current +12V rails with high maximum load for better graphics card compatibility
- Quiet 135mm double ball bearing cooling fan with low start voltage
- Four gold-plated 8 (6+2)-pin PCI-E connectors for multiple-graphics card configurations
- ATX12V version 2.3 and EPS version 2.91 compliant
- Universal Input - works on any 100V - 240V grid
- Active PFC with PF: 0.99 - less harmonic pollution, greater efficiency
- Full suite of industrial grade protection:
- Over voltage protection (OVP)
- Short circuit protection (SCP)
- Over power protection (OPP)
- Over temperature protection (OTP)
- Safety: cUL, TUV, CE, CB, FCC, C-TICK, CCC, BSMI, Gost-R
- AQ5 Antec Quality 5-year limited warranty on parts and labour
Only £97.99 inc VAT.
ORDER NOW
Antec High Current Gamer 900W Quad Rail Power Supply @ £114.98 inc VAT
Making quad rail power and highly advanced power supply design available at a popular wattage, the HCG-900 features special High Current connectors and heavy-duty cabling, earning it NVIDIA® SLI®-Ready and ATI™ CrossFire™ certifications. At the same time the HCG-900 is also 80 PLUS® Bronze certified for efficiency, and features active PFC with a swift, quiet 135 mm double ball bearing fan so you know you're getting not only High Current, but also high efficiency and excellent cooling. If loads of power, High Current engineering and exceptional efficiency are what you're after, the HCG-900 is the perfect PSU for you.
- 900 watts of Continuous Power
- AQ5 Antec Quality 5-year limited warranty on parts and labor
Only £114.98 inc VAT.
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
