Antec Kuhler H2O 920 CPU
2 Mar 2010
Never had a liquid cooling system looking to get one tho :).. does this really need no maintenance whatsoever? How is this different from any other liquid cooling
The Antec Kuhler is a favourite for CPU cooling, but tbh there isn't much difference between the Kuhler and the Corsair H80. However if you've got space in your case look at the Corsair H100.
And no, no self contained CPU cooler requires any maintainance
The H100 is considered loud by some, but personally I don't think it is, but you could always change the fans it comes with, a lot of people do
You probably could email OCUK and ask if they can replace the cooler, they might be able to at some cost to you
High end air coolers are better in terms of performance and they are both neck and neck when it comes to noise.
The DH14 would be my choice, but the Antec is a very good CPU cooler at a great price.
The DH14 seems to be the best competitor against self-contained water coolers, but it's size is offputting
Lol thats ok then, I have the HAF 922
It's down to personal preference, I have the H100 and I love it, it was £80 but having looked at the temps I'm extremely happy with the purchase
In terms of performance i've seen the 920 better the d14 which is why, since they're both the same price £61, im getting 920.
Quick question: How is this with the i52500k extreme oc? Like 4.5/5.0ghz?
And is silent mode actually silent?
Link/source?
If the DH14 has proper airflow, it will be better
not bad, but a 240 rad would be better, as would a DH14
yes
