Antec Kuhler - normal pump noise level?
26 Jan 2007
Leeds
Hey guys,
Short Version
Picked up a Kuhler 1220 and fitted this weekend. Great cooling, but the pump sort of chunters and hums - wondering if that's normal, or whether it needs RMAing?
Long Version
So yeah. Absolutely cannot complain about the cooling performance - literally taken 30 degrees off my gaming temps, and 20 off stress testing. Brilliance in a plastic package, really.
On the other hand, while it isn't loud, it's not exactly as quiet as the reviews I'd read about it, which were all gobsmacked by how "silent" it is. Since the monitoring software can't find the fans, I've got them on manual control at minimum rpm, and they themselves are inaudible over the hard drives.
The pump meanwhile - when ChillControl can find it, which isn't every time - is constantly at it's maximum 3000 rpm. While not loud per se it distinctly... chunters, when the system is warm, being louder than anything else in the case by a big margin. This is annoying, because on the rare moments it dips to 2800 rpm or less, suddenly it goes quiet. I am quite sure this would be enough to keep things cool, given the headroom it has at 3000!
As it stands, it's about as loud as a small fridge. Less noisy than air cooling would be when keeping an overclocked 2500k at 45 degrees while gaming (again, wow at the cooling performance!) but plenty to be noticeable. It's been running for about 24 hours over the weekend, so if it was a bubble issue, I'd have expected them to settle out by now.
While my old air cooler would have either whirred madly at high load, or had the CPU in the high 70s, it did at least settle down to silence when idling/photoshopping/browsing/etc. TBH I think I preferred that scenario, since games invariably come with sound effects. If pump rumble is the standard thing with watercooling, I may have to re-evaluate whether I want to stick with it. Which will make me sad because it's undeniably effective :(
Cheers for any information!
It should hum a bit but anything else could be a air block etc.
So while its running try tilting the case in different angles.
I'm probably just hearing the normal hum then, but I'll lie it on its side when I get home tonight, cheers :)
(Slightly tetchy about the reviews if its normal noise - saying the fans are totally silent while not mentioning the pump noise isn't quite cricket...)
Ooo... well, this is awkward.
Turns out the fans have been very subtly ramping up even though they're not plugged into the pump's fan outputs. The ChillControl software seems to take control over every fan header on the motherboard. Having fitted an inline resistor and dialled then back down to minimum again, the noise dropped off. Admittedly Prime95 temps jumped from 62 to 70, but I'm fine with that in a quiet build!
Also thanks for the tilting tip guys, that seems to have reduced some of the vibration/hum from the pump itself. Currently lying on its side at a 20 degree kilter and much less obnoxious :)
Soon as I can replace the fans, and possibly get a fan controller in there, figure it should all settle down to something I can live with ^^
Success! I found an old 3-port, 3-pin fan controller with nice analogue dials, and swapped out the Kuhler's fans for a pair of Gentle Typhoons.
Fans on minimum are immediately quieter, and running the pump itself off the controller, turned down about 20% has taken away the waspish edge to its noise. Oddly, the monitoring software still reports 3000 rpm on the pump, so we can pretty much assume that it is worthless and should be ignored...
Currently priming at 69-71 degrees, in 24 ambient. Reckon once I close the case up it'll be one of those "is it actually on?" systems that you have to check the LEDs to know for sure :D
Again, thanks for the tilting tip, there was definitely a bit of bubbly noise that went away after lying the case at a different angle last night. Also nice to know that the hardware is tip top, even if the control software is basically pointless :)
