Yewen said:
LG drives if I remmeber correctly, having the potential to have it happen is bad enough in my books. Never said it was a bad case, just that the build quality is less than the Lian Li.
Really? Isn't that strange that LG drives are slightly different? I would have thought it would be a standard across everything.
Yewen said:
The first can be done for £2 in the PC7, the cable management is a good feature but the PC7+ can be made to hide all cables and the sound dampening is very gimicky in my eyes, a loud PC in a case is still a loud PC in a low noise case. Never found one where they make a bit of difference.
Yes you could do something similar in the PC7, but it's there for you in the P150, it's purpose built and I'd say it's a lot better than a custom jobbie. Obviously if you don't have it already there you have to DIY, but it was another big selling point for the P150 in my eyes.
The cable management is exactly the same; you could do similar in another case, but the P150 has it all there ready for you and it's an excellent system.
As for the sound dampening, it's going to work better than not having it. Sure a loud PC is a loud PC, but it's going to be dampened in some way, shape or form by having the covering on the panels. A quiet PC is going to be slightly quieter and a loud PC is going to be quieter by what will probably be an indistinguishable amount. Mine's a quiet PC and it'll be even quieter with the deadening!
Yewen said:
The p150 comes with a psu, so obviously less money from its total price goes to the case, but it does make it good value. If you plan to use the PSU then it is the better option, if you are going to chuck it out then the case is not worth the money at all.
Good little PSU too. Not much use if you're Crossfiring/SLIing, but it's pretty handy for modest setups and having the cables pre-sleeved and modular is everything I want in a PSU.
It's not the type of case you'd want to be transplanting your existing system into (unless you really wanted a modular PSU) but it's ideal for the first-time buyer, like me. And if you're planning on building something quiet, like white and silver and blue lights - buy it, buy it hard!
kbc; when I finish building my system I'll set my studio up and take some high-res shots for you. It'll be about a week until I get the chance to do so, so can you wait or are you in a rush? If you're in a rush, trust me and buy the P150 if you agree with my reasoning above.
