gr1mey said:the P180 is designed for silence, but IMO, and also a lot of others, its also a fine looking case.
In any effect, if you cut a window it wont reduce the sound deading qualities by that much seeing as the window you cut will only be small due to the internal layout of the case.
gunner said:Kind of defeats the point of the the P180.ie. sound proofing baffles
