Antec P182 problem (buttons/leds dont work)
26 Dec 2008
Scotland
Hi guys
I have an antec p182, and for some reason the front leds (power/hd activity) and the buttons (reset/power) do not work. its not just one of them thats the problem, but all.
I originally thought the problem was the motherboard. But even after RMA'ing it, the buttons still dont work
any ideas what it could be?
cheers
hideki
You have to get it right, have a look at your motherboard manual and make sure they are plugged in the right places and the right way round (positive, negative, etc)
motherboard is an asus p6t deluxe
connections are the standard motherboard headers
reset, power switch, power led and hd led 1
i plugged them in as directed by the manual, and have tried putting them in both ways
the usb and sound headers are working fine
well, i solved the problem by using the asus "q-connector"
no idea why the normal headers didnt work
