- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
*** *** Antec Veris Multimedia Station Basic - Retail @ £22.99 inc VAT *** ***
The Multimedia Station family is a complete solution for home theater PC builders: a stylish IR receiver, a remote control and iMEDIAN HD by iMON software for media management and playback. With four distinct models available, the Multimedia Station can fit the needs of all builders, while the included MEDIAN HD software allows supports full 1080p resolution and is compatible with Windows MCE and all versions of Vista and XP. The Multimedia Station provides all the hardware and software you need to turn your PC into an entertainment center, in an easy to use, easy to install package.
- IR receiver can be powered on the remote or by preset power schedule
- IR receiver mounts in external 3.5" drive bay
- Petite and useful remote allows user to control, play and manage all media, browse data, and change settings
- IMEDIAN software allows the playback of most media formats through internal codecs, full 1080p HD support, and a simple and convenient graphical interface
- Support for CD/DVD, removable storage, network media, and digital/TV analog cards
- Fully compatible with all versions of Windows XP and Vista
Only £22.99 inc VAT.
ORDER NOW
ORDER NOW
