Ok - maybe a strange question but here goes;
due to the strange setup I am after I would like to know whether people think having a case is important?
My plan is to "wall mount" the mobo, HDDs and power.
Not just screw them to the wall but not far off either, the power would sit on a beam 30cms from the ceiling and then the mobo attached to some wood screwed to the beam with the hd drives also mounted.
now what are the major issues with doing this? I will enclose the area and add a few fans front and back so air circulates, but what I want to know is, if it isnt needed will a lack of a case be a big issue?
(power will be easy enough to sort with a button attached to the enclosure)
