If you stick another single 1GB stick in, you'll lose dual-channel support which, depending on what you do, could slow you down more than the additional memory would benefit you.
Not quite true my board still works as dual channel even with 3 sticks in im sure its not just unique to my board either but i do rememeber the amd boards on 939 did lose the dual channel with 3 sticks so i can see why you think that.
actually, i think only 2GB of your ram runs in dual channel, the other GB runs in single channel, i think thats how intel chipsets do it. ive tried both single channel and dual channel though. i didnt really notice a difference. Ram at that speed has a pretty high bandwidth anyway.
Intel chipsets run single + 1 channel with 3 sticks so no, you won't loose dual channel performance. Best to go with 4gb even if you don't use it all though.
From my experience upgrading to 5gb of RAM in a 32bit os actually lead to performance decrease anyway :\
So to be honest, unless you really really need it id suggest just sticking with 2gb or upgrading your OS.
Well, Windows and Everest says I now have 3582 RAM, so in essence I've lost about 500meg but I don't really see myself splashing out on v64 purely to get the RAM back. System seems to fly. All 5.9s bar the CPU which is 5.7. Room for improvement there but my chip is clocked at 3.2 (e2160) so I'm gonna leave as is.
