Been sick of the k70 spacebar/enterkey/delete key rattle for ages now, it makes the keyboard feel so cheap.
Anyway its very simple to fix. The problem is the stabiliser keys, not the actual cherry keys.
The base that connects them to the keyboard is loose and flaps around making the rattle, jiggle them with your finger and you will see how bad they are.
If you take a little bit of thin plastic (I chopped up some paracetamol blister pack) and shove a little bit under them it stops ALL rattle making the keyboard sound and feel like other mechanical keyboards.
Here is a photo, do this to all the stabiliser key connectors and your keyboard will feel 100x better, no more cheap sounding rattle!!
