Any downsides to using an M2 drive instead of a SATA SSD?
17 Nov 2007
As per the title, I've always wondered: M2 drives generally have tons better speeds than a regular SATA SSD, so given the same capacity and price points, is there a reason why someone would use a normal SSD (apart from the obvious "no M2 slots on the motherboard")?
M.2 is just a slot, which doesn't specifically give you the higher speed. You can get SATA M.2 or you can get PCI-E M.2 slots, the latter being better due to direct PCI-E lanes to the slot, and an NVME drive can make full use of that bandwidth.
There's little real world difference between the two for the majority of users though. The main benefits are from having no SATA and power cables going to the drives for a cleaner look.
Ease of physical access might be factor. M2 might be under a graphics card whilst 2.5” is more likely to be in a dedicated drive bay/mount.
Do the PCI-E adapters maintain the same level of bandwidth as an original M2 slot or would that depend on the mobo and the PCI slot?
As long as it goes in a min of a x4 slot (PCIe 3.0) then it will be as fast etc. as in a dedicated M.2 slot. I've got an MP510 in an add in card and an 970 EVO in a dedicated M.2 slot, and both work/test as expected (PCmark 8 storage test looks fine in both cases).
PS. In my case... graphics card in top slot (x16), add in card to support the MP510 in the bottom of the 3 PCIe slots (x4).
A SATA SSD is more easily transferable. Can you guarantee that your next motherboard will have a M2 slot? If you need a PCIE card, will it be bootable?
Very little in life, bar death and taxes, are guaranteed. But for the foreseeable future, I can't see the OP has any worries that the m.2 socket will be dropped any time son.
