- 28 Oct 2004
- Somewhere, in a field in cheshire... alright!
Hello,
Can anyone suggest a good indoor DAB aerial that will likely give a better reception than the wire that came with the CD/Radio. Under £20 or there about ideally. The signal has got so bad now it's almost unlistenable, the signal goes completely every so often for about 5 to 10 seconds. It's a Panasonic and the aerial screws into the back.
Any suggestions will be appreciated.
Thank you.
Thank you.
