any help on weird thing in bf2
10 Feb 2003
skelmersdale
right bought a 7900 gs about as my 850 xt pe is getting a RMA ,all was well until a few mins ago when playing bf2 4 hours straight .
all of a sudden this came on screen and wont go away:-
any ideas ,is it a memory problem? :( :confused: :o :eek:
Definitely RAM if it's hardware. Tried reinstalling bf2/drivers? BF2 just happens to be insanely buggy :(
How long you had the GS ?
What drivers are you using ?
Did you use driver cleaner to get rid of the ATi drivers ?
Have you been messing with your settings in BF2 recently ? If so clear your cache folder/file.
Temps of the card under load ?
How good is your case cooling ?
What PSU you got ?
