Any help or guides towards optimising my 3600?
16 Sep 2020
Hi all,
Sorry, new here and havent messed with pc hardware for a good while so a bit behind the times. I have recently added a ryzen 3600, and am getting some poor scores comparativly on cinebench. My temps are also pretty high. I am using the stock cooler though, so i suspect its that. Aside from the xmp profile, i havent changed anything in the bios either.
On cinebench im getting 3446 , which seems way off some others.
Also took some screen grabs of my temps and fan in hw monitor. Thats just normal browsing and the spike is launching gears tactics.
https://imgur.com/deQLHlg
https://imgur.com/OkW9b8n
Any tips?
Thanks
All looks find to me, your cinibench score 461 is not to far from the average 472.
There are things you can do to optimize ryzen cpu, a quick Google .
Grab yourself a a cpu cooler to keep temps and noise down and then may be some overclocking.
Would you consider a new cooler ?
Yeah, might pick up a 212 black edition. Seems the best without spending a lot. My fan noises are quite loud, the case has good airflow too. Ill have ot turbn my famns off one by one to make sure it is the cpu fan thats loud before i order. Hopefully its just a cooling issue and the cpu maybe throttling?
Arctic Freezer 34 eSports same money but better cooling .
https://www.overclockers.co.uk/arctic-freezer-34-esports-120mm-cpu-cooler-black-grey-hs-07e-ar.html
1usmus should have his tool out in next week or two, this should give you a small boost but also a bit off power consumption.
