- 9 Jan 2005
- Stoke-On-Trent
I have the
Antec Fusion Black HTPC Case - 430HE Watt PSU
I would have put my old 600what Enermax noisetaker in there because 430watt seems a little low if I want to put a newer graphics card in there I'm currently using a 7900GTO. The problem is the Enermax dosen't have a cable to connect to the front LCD on the case where the Antec one does. I've only ever seen the connection with the PSU that's come with this case.
I'll want to get a better PSU in time and would like to know if there's any other PSUs which have that LCD connection.
I'll look for a picture ofit if that helps
However the GTS cards are fine.
