Any idea what is wrong?
24 Oct 2009
Edinburgh
Hi everyone, I just built a pc based on another mobo. P5Q Deluxe.
The problem I am getting here is everytime there is a overclock failure. The screen won't load up, leave me a black screen like no graphics card is present. Everytime I have to switch off the main power to get the loading screen appear again.
Anyone knows where the problem is? why I can't get a load message if overclock failure happens?
just reading through the forum, can I use this setting?
Quote:
AI Overclock tuner: MANUAL
CPU Ratio Setting: 9
FSB Frequency: 450
FSB Strap to North Bridge: AUTO
PCI-E Frequency: 101
DRAM Frequency: 1080
DRAM Timing Control: Manual (5-5-5-15)
DRAM Static Read Control: DISABLED
DRAM Read Training: DISABLED
MEM. OC Charger: ENABLED
AI Clock Twister: Lighter
AI Transaction Booster: MANUAL
Performance Level 8
ALL PULL-INS DISABLED
CPU Voltage: 1.4
CPU GTL 0/2: Auto
CPU GTL 1/3: Auto
CPU PLL Voltage: 1.52
FSB Termination Voltage: 1.22
DRAM Voltage: 2.1
NB Voltage: 1.24
NB GTL Reference: AUTO
SB Voltage: AUTO
PCIE SATA Voltage: AUTO
Load Line Calibration: ENABLED
CPU Spread Spectrum: DISABLED
PCIE Spread Spectrum: DISABLED
CPU Clock Skew : AUTO
NB Clock Skew : AUTO
CPU Margin Enhancement: OPTIMIZED
C1E Suppport: DISABLED
Max CPUID Value Limit: DISABLED
Intel Virtualization Tech: DISABLED
CPU TM Function: ENABLED
Execute Disable Bit: ENABLED
Intel Speedsteb: DISABLED
Intel C-state: DISABLED
My current memory are OCZ Platinum Revision 2 XTC 4GB (4x1GB) PC2-6400C4 Dual Channel Series (OCZ2P800R21G)
If you are unsure what your doing copying another user is the worse thing you can IMO. Set every thing to defalut, get the info from your sticker on the ram sticks input in the bios correctly then overclock the FSB as normal and find out where your system is falling over
I would like to try them one value by one value, but the annoying thing is everytime it failed, it did not show me the load up screen, so everytime I need to reset the bios, which is a pain
So anyone knows how to prevent the loading screen from disappear?
