Hi.
Ive got a very annoying problem, that if i was experiancing at work, i would be telnetting onto the switch and looking at the stats to diagnose.
Unfortunatelly, my gigabit switch is a £25 netgear one, and has no such feature.
So. My main PC, with a realtec gigabit NIC in it, connected by a 2m Cat 5e UTP cable, to a Netgeat 5port Gigabit switch, with 3 other connections in it, 1gbps NAS, 1gbps PS3, 100mbps ADSL WiFi router.
Every now and then, the link speed between my PC and the switch will drop to 100Mbps.
I set the device properties to force 1gbps, and for the first few mins it would connect/disconnect every 1-2 seconds. I unplugged every device apart from my PC from the switch, and plugged them all back in, one by one.
It now appears to be working.
Anyone got any idea whats going on?
Thanks in advance all.
