Any laptops with sturdy charging ports?
31 Dec 2003
Stoke on Trent
Hi
Every laptop I've ever had has eventually had its charging port broken. We share the laptop between rooms, plug and unplug it all the time and whilst I don't think we treat them too rough, there are kids using them so......
Last laptop was a USB-C charger and I thought this is it! This is the solution as it's surely more solid than the old barrel type, but no, that's now broken too.
Can anyone think of a model of laptop which has a really sturdy charging port for this use case?
There are laptops with magnetic charge connectors. The more recent MacBooks have these (again, after Apple stopped for a few years) and I know Surface laptops have them too.
There may well be others, but I’d definitely be trying to find something with a magnetic port.
You can also get magnetic USB-C cables/adaptors. I have tried a few over the years for the kids with their iPads but they all seem to get a bit flaky over time. Maybe someone can suggest some that are reliable.
Not quite what you are asking for, but as a sideways solution the approach with Framework laptops helps! I wouldn't have said it feels sturdy, but the fact that the replacement port is £9 - (USB-C expansion card) is a solution at least! I got 2 with my AMD 13, bonus is being able to place one on each side so it doesn't matter so much how my laptop is oriented.
All that said, last week my GF managed to break the cable from the USB-C docking station rather than the port on her laptop while putting it back in her bag without unplugging it :rolleyes: Fortunate I guess given it is a brand new laptop from a new job she has started with.
Good point, the one on my surface pro tablet is *clearly* not going to get damaged by its design.
I'm gonna try a magnetic usb c converter for the laptop we're currently using
I've not personally tried them. But you can get "magsafe" adapters for USBC ports. You leave one part of the adapter in the port and another part of the adapter on the end of the USBC cable to charge it that way. It should save wear on the port.
Quick update I bought one similar to these, £14 and so far I'm really happy with it. Wish I'd have had it years ago
