Any major Difference??
17 Mar 2005
London
XFX 7900GTX 675/1700 vs EVGA 7900GTX EGS 650 any major performance difference?
Hi,
I have ordered/gona order a XFX 7900GTX 512mb 650/1700 Extreme card but noticed its very out of stock!
Is a 512MB EVGA 7900GTX EGS ,Mem Clock 1600 MHz ,GPU 650 MHz , 24 Pipes, Dual DVI-I , HDTV any good or am I better waiting for the slight increase?
EVGA cards are generally reckoned to be very high quality.
You'll almost certainly find that it will overclock very nicely anyway.
Hav
I guess there wouldnt be any major performance difference would there? and the difference in clock speak I can just OC too with decent cooling?
The stock heatsink is more than enough its great.
And you will easily overclock to 680/1750 on the ram I would have thought :)
Just get the one thats in stock :D
