2 Apr 2009 at 19:45 #1 Hantheman Hantheman Associate Joined 3 Mar 2009 Posts 9 Intel Core 2 Duo E8500 4.0GB Corsair DDR2 800mhz XMS2 500GB S-ATAII 3.0Gb/s NVIDIA GeForce GTX 260 896MB ® Windows Vista Home Premium SP1 64-bit Wireless 802.11G PCI card Or will a 500W do the buisness?
2 Apr 2009 at 19:53 #2 RIZZEE RIZZEE Soldato Joined 31 Jan 2009 Posts 4,248 Location London dont think you'll need a 700W psu for that, 500w should do fine
2 Apr 2009 at 20:03 #3 Fire Wizard Fire Wizard Man of Honour Joined 17 Oct 2007 Posts 3,871 If you get a PSU from a good manufacturer, then 500 watts will be absolutely fine. Something like the Corsair VX 550W ATX Power Supply will be fine. If you want a modular PSU, then either the Corsair HX 520W ATX Modular SLi Compliant or Be Quiet! Dark Power Pro 550W ATX2.2 Modular SLi Compliant are both excellent choices. If you want some breathing space for upgrades in the future, then the 600 wattage models from the above manufacturers would also be a fine choice. Last edited: 2 Apr 2009
2 Apr 2009 at 21:43 #4 icey_haj icey_haj Soldato Joined 28 Feb 2008 Posts 3,374 Location Birmingham ^ I concur with the new Underboss. Have a look at Corsair, BeQuiet!, Coolermaster and Zalman for your choice of brand.
2 Apr 2009 at 21:49 #5 RJC RJC Don Joined 29 May 2005 Posts 29,080 Location Kent Indeed 700w is overkill, running the Corsair 620w & 520w versions and not had any problems.
