HP Reverb on Amazon (with controllers) ATM for less than £500!
https://www.amazon.co.uk/dp/B08BFKQGN3
Thanks.
Is the G2 worth a shout over the quest 2?
Quest 2 128GB is calling for you. A great standalone unit and if you want PCVR - you can tethered or wirelessly.
If you're referring to the 128GB, yes you're correct. The Q2's onboard storage is just for Oculus standalone games and whatever media you have. I have the now replaced 64GB version with around 9 games installed and still have ~32GB free. As for your PC spec though - you will need something fairly good to get the most out of it (my 3700X, 32GB, Vega 56) does a pretty good job but my GFX definitely is the weak link if I wanted to play AAA games/highest settings going forward.I assume the amount of RAM is irrelevant is using for PCVR?
Quest 2 is great, can definitely recommend as I picked one up recently. Though I would suggest waiting just a few days to see if it will drop down major prices, since it was £199 not too long ago
Around June time, I remember I saw it on Very but didnt snag it as I was stupid.When was it £199???
£199 was probably clearing out the 64gb models.
