any point of sound card with usb headphones?
anyone know if the comp will use the soundcard if i use usb headphones?
You cannot use any controls or inputs or outputs or bass and treble controls when using USB headphones or headset.
connecting USB headphones/headset or usb speakers bypasses the soundcard.
hmmm ok thanks. howcome then usb headets seem to be rated better than socket ones?
think im going bypass getting sound card then and just get some ambx and usb headset
The question in the title is the wrong way round. It should be "any point in USB headphones with a soundcard?".
With all but the most basic soundcards, the answer would be a definite and resounding "No".
