- 26 Aug 2010
- West Yorkshire
Here's the specs for my summer build project. The cpu and motherboard will be replaced with the haswell equivalent on release (they are placeholders), and i'll probably buy the monitor while it is on offer today, but i'd like to see what you would suggest. (the watercooling stuff is temporary for now so may not all fit together as i'll go into detail in that closer to the time)
YOUR BASKET
1 x Gainward GeForce GTX Titan 6144MB GDDR5 PCI-Express Graphics Card £799.99
1 x Crucial M500 960GB SATA 6Gb/s Solid State Hard Drive - (CT960M500SSD1) £487.99
1 x Dell UltraSharp U2713HM 27" Widescreen LED Monitor - Midnight Grey £439.99
1 x Corsair Obsidian 900D Super Tower Case £299.99
1 x Gigabyte Z77-G1-Sniper 3 Intel Z77 (Socket 1155) DDR3 Motherboard £299.99
1 x Intel Core i7-3770K 3.50GHz (Ivybridge) Socket LGA1155 Processor (77W) - Retail £279.95
1 x Seasonic 860w '80 Plus Platinum' Modular Power Supply £169.99
1 x TeamGroup Xtreem LV 16GB (2x8GB) DDR3 PC3-19200C10 2400MHz Dual Channel Kit (TXD316G2400HC10QDC01) £119.99
1 x Corsair Vengeance 2000 Wireless 7.1 Professional Gaming Headset £114.98
2 x XSPC AX480 Quad Fan Radiator (Black) £109.98 (£219.96)
1 x XSPC Razor GTX Titan GPU Waterblock £94.99
1 x Aqua Computer Aquastream XT USB 12V Pump - Ultra Version £79.99
1 x XSPC RayStorm CPU WaterBlock (Intel) £51.98
1 x Bitspower Z-Multi 400mm Water Tank £42.98
4 x Corsair SP120 Quiet Series High Pressure Low Noise - Dual Pack (CO-9050006-WW) £25.99 (£103.96)
1 x EK Water Blocks EK-FC Titan Backplate - Black £24.95
1 x Corsair AF140 Quiet Series Low Noise High Airflow - Single Pack (CO-9050009-WW) £14.99
1 x ModMyMachine Shoggy Sandwich V2 for your Watercooling Pump £6.98
2 x XSPC HighFlex Hose 3/8" ID, 5/8" OD, 16/10mm, 2m, Clear £6.49 (£12.98)
1 x EK-EKoolants UV Green £5.99
10 x EK PSC Compression Fitting 13mm 3/8" - G1/4 - Black £3.89 (£38.90)
Total : £3,738.16 (includes shipping : £22.20).
This is my plan:
YOUR BASKET
This is my plan:
