- 15 Feb 2011
- Slough
on the weekend i'm going to have to move my PC back to uni. before this wasnt a problem having it strapped in the back seat of my dads car because it only had the standard cooler. however, it now has a giant cooler attached to it, so transporting it could break my motherboard.
since the cooler actually pushes slightly against the side of my case i was planning on laying the PC on its side so the cooler is resting on the floor, but, aside from using a lot of string around the heatpipes, i cant think of anything i can do to support the cooler while i carry the PC
anyone got any bright ideas?
*edit*
i meant to say that i dont have any TIM left, so i cant remove it
*edit*
ive got the same chip with the standard cooler and its not that bad, saying that it is the nosiest fan in my case tho, aprat from the gfx card one under load. The only other option i can think of, and what i would do if i had a big arse cooler on my MB, would be to fabricate some sort of bracket up that holds the cooler in place, like connects to the cooler and bolts onto the case somewhere.
