Some HPI checks will show if the plate has been changed since it was first registered.
If the actual location of the vehicle and the area code of the plate are different, it might indicate that it's a private plate.
[TW]Fox;22332765 said:If it's a 2012 car with a 12 plate then the only way to tell is to guess.
Usually you can tell as the plate doesn't quite match the car. Whats the plate and car?
[TW]Fox;22332934 said:All proper HPI checks will show you this. But I rather suspect he wont want to spend money finding out if a car down the road has a private reg![]()
