Any way to boot a PC with a wireless device?
25 Oct 2003
Hi, I have recently built a PC that boots into steam big picture thanks to the awesome help on this forum :)
What I'd now like to be able to do (and can't seem to find an answer for) if boot the PC with either my wireless keyboard/mouse or a controller (currently using XBO via official dongle).
I suspect this isn't possible after my search but am hopeful someone may know better?
Edit; Hhhmm...maybe I am overthinking this? What if I didn't switch the PC off - just went into a sleep/hibernate mode? Is there a was to use wireless then?
Thanks in advance :)
Some sleep modes are able to be woken from USB. maybe an IR remote can wake it. otherwise you can wake it from another device, laptop/smartphone using magic packets/WOL (wake on lan)
If you have a wireless keyboard plugged in, most BIOS allow you to set a wake up event based on a keypress (this should even work from being powered off)
Don't know whether they have started removing this from the latest BIOS as it is a few years since I last set this up
Check the bios for a setting for 'wake on keypress' - I had an old gigabyte motherboard that had that setting.
(At least, I think it was Gigabyte)
