Does anybody know if it can be done?
Also, does anybody know if it is possible for me to set my Zalman gfx fan so that it varies the rpm according to the temp of the card? Im currently using a fan controller but its annoying having to manually adjust the speed of the fan all the time.
Cheers.
Cheers.
