Anyone awake? need help :(
Ok so i tryed to boot from disk and it worked but the bit when it tells you to pick a partition went wrong. I picked one and it would'nt let me at all :| So i did the IDE thing you said stuild and it got me to my desktop, did a bunch of driver installing then restarted and all seems well again. So i'll try boot from disk again for a fresh install. Man alice what a faff on!
You want AHCI ideally.
So set it back to that and try the install again.
When you get to that partition thing, I just delete them (usually 2, with one like 100MB) then click next.
Whats the difference between them?
Will do :) No need to backup all my games are saved within steam and origen and dont keep anything on it, pure gaming prowess.
I've played with it a bit just out of curiosity before i go ahead and do the above and omg the sound qual of that board is amazeballs!
Ah ok so a slight speed boost basically, cant complain at that thanks. I have done as you said stulid and its finnaly doing what its told, on with a fresh install now. Man im gonna be up all night!
Thanks for your help mate, and everyone else i'd be lost without the help i get from here.
EDIT: Yup old skool HD for now
What OS are you running? IDE is fine for xp,win7 you can do a reg tweak for ahci edit Nvm if your doing clean install
^^ yea i didnt do a fresh install, same brand mobo but my old setup was amd athlon
Just a note, it may be the same brand but it's a completely different chipset, sata controller, etc etc... It's usually if the chipset is the same you can sometimes get away without needing to do a fresh install.
All is well and running now, had a massive drama trying to get windows update to work, will make a post about it as it took forever to find the right fix.
Mate the sound is fantastic! I like to think i know good sound too (guitar player) i have'nt as of yet as i like things a bit heavy on the bass and read the other amp is a lot cleaner. However after a days gaming i'll try the other one out to tell you how it actually is :)
