anyone had problems with EK
prt
prt
1 Jun 2009
Cardiff
Hi all,
Anyone had any problems with the EK full cover water block for the Gainwood 260 GTx card.
Seems this 1 i got here the black alu end is not touching down on the Tim over the ram/vrm block. Almost looks like it is sitting up on the R30 blocks.
shot of end block
I would certainly contact the vendor you bought that from because it should fit. Are you sure the board isn't buckled because of over tightened screws? looking at this further.. the board is dipping down slightly to the right..
Several aftermaket air coolers for GPUs suffer from this aswell, just stick a thicker thermal pad in here :)
