- 6 May 2011
Hi
I asked this a while ago but seem to have drawn a blank:
When I boot up my system the monitor doesn't fire up yet i can hear w7 loading. However, when I press the 'reset' button on the rampage 2 mobo, it boots up fine and the monitor gets a signal. So it appears that the gfx card doesn't send a signal until I reset. Once the system is up and running, I can restart no problem, it is only from a cold boot up that there seems to be an issue.
This has only happened since I swapped gfx from a 6950 to 6990 and the card itself works fine. Any ideas?
Cheers
Cheers
