AtlanticP,
Thanks for coming back with your reasoning. Though you arn't compressing the spring to lower the car, just adjusting the spring perch height. Same amount of preload is on at all times, plus putting spring load on does not increase the spring rate on linear springs. Fortunately for me too is my shocks have been ran at the ride height I am looking at so I don't have to worry about it being out of range. I don't need new dampers as I already know 300lbs front and 220lbs rear is well matched for the valving, this is the whole point of me changing my spring rates so it matches the damper better. For some reason they sold the Bilstein with far too low spring rate, which just meant it went onto bumpstops all the time.
Clarkey,
I recognised that name, had a look on a few mx5 forums and thats what the americans seem to love using. Looks like it must be all fine then on the mx5, just need to make sure the sleeve will work correctly with my factory option Bilsteins.
Edit - Just thought, I will be able to do corner weights properly when I get my geometry sorted.
Clarkey,
