- 21 Apr 2007
I'll try keep this super brief but basically week back my pc started blue screening constantly and I had no idea why, did a little digging found out ram can cause blue screens. Now I've always had blue screens since I built this pc couple months ago, only very occasionally (but my pc before I never blue screen I put it down to windows 8 being gay). But it got worse week back.
So I get memtest and test my ram, comes back with 1705 errors I'm like WHAT THE HECK?! so I then test other stick get no errors.I then go into bios to check ram settings see one of settings on my mobo to boost ram so I turn that off and although voltage was already auto 1.5 I set it to 1.5 manually to make sure.
I then try the stick with errors again in another slot and get way less errors like 10 or something. (I also tested the second "good" stick multiple times and one time got 1 error on it) Basically I ran memtest a few times on each stick once. Eventually errors stopped? so I then popped both sticks in ran memtest and got no errors so thought ok must be ok right?
I freshly reinstalled winodws few days back when I was testing the sticks and It's been ok for like last 4ish days and just had a blue screen again. Not constantly yet.
Any ideas on this? what are my next moves?
Thanks
My Mobo is a gigabyte Z87D3HP
https://www.overclockers.co.uk/showproduct.php?prodid=MY-132-CR
And that is my memory.
Thanks
