- 8 May 2010
- London
I've been thinking about adding a second-hand beer cooler to my loop. The reasons for this are:
1) I would like the fans on my radiator to point INWARDS into the case thus making the case 'air-conditioned'.
2) I get 34 degrees at the moment with a 4GHz oc and it never changes.. due to the large rad. This is currently cpu and north bridge only but will be adding the 5790 when I get a block.
3) The 'case' is a custom build with open sides so there is plenty of air circuation and as such no other internal fans are required.
4) I have looked at beer chillers, particularly the ones that cool the Python from the beer kegs to the pump, as these also have a built in pump and run 3/8 ID piping. These can be bought for around £150 and can supply 600w of cooling. I reckon that this would be plenty as I already have a large rad with 4 160mm fans on it.
5) My current loop is 1/2" ID although I noticed no discernable improvement over the 3/8" ID loop I had before.. so it makes no difference going back if the improvement is worthwhile.
6) The function of this is not to have it on all the time, but mainly for weekends when I spend a lot of time gaming - during the week the coolant will run through the cooler but it will be off. I envisage adding another pump to maintain flow rate over the 5M of added pipe. The cooler takes about an hour to come online and during this time, the PC has to be off to allow it to 'make ice'
I have done phase change and cascade back in the day, but this idea appeals because it means I could put the cooler next door in a cupboard so no noise. i can then run the pipes under the floorboards! I am not looking for sub zero temps, just reducing the loop temps to between 10-15 degrees would be great as I wouldn't have to worry about condensation.
I know I'm barking lol. So has anyone actually tried this before and got some decent results?
