Anyone using a butchers block countertop as a desk?
19 Jan 2005
Cambridge
I’m thinking of making a desk using a butchers block countertop on top of the Ikea Alex drawers. If I do this will I need to oil/seal it somehow? I know this is recommended for kitchen tops that are regularly coming into contact with water but is it needed for a desk?
I guess I just want it to be scratch resistant and be able to handle the occasional accidental drink spillage.
The site I’m planning to order from will apply Osmo top oil for an extra charge but I’ve read that oiling can leave them permanently sticky. Also I would also rather not change the colour of the wood, I know some furniture can go orange when oiled which I don’t want.
I bought a B&Q kitchen top 10ft long and cut off 4ft.. works great for me and coffee stains etc wipe off easily. Both over the top of my two desks etc.,
I’m using a 3M solid black oak kitchen top which I’ve applied 3 coats of oil onto and it’s not at all “sticky”, nor has it really changed the colour..
#2971
Loads of people do it. Best desk you will ever buy. I got mine from IKEA at least 5 years ago and haven't had to oil it.
Also if you find somehow it gets really scratched then just sand it and oil it then.
Osmo oil is great. It doesn't leave the surface sticky. I'd recommend applying osmo yourself though, because once the worktop arrives you might want to sand down the edges or corners a little more anyway. If there is one thing worth paying extra for, it's to get the worktop to get it professionally chamfered on the edges.
If doing the Osmo oil yourself, you can pick from the multiple Osmo oil types. There are clear matt/low satin ones, which don't stain or alter the colour but still provide a clean & smooth water resistant finish without being shiny.
I followed this guide:
An alternative to using the Ikea Alex drawers, if you don't need drawers and would prefer more legroom/PC space, is to buy some steel table legs from Amazon, make sure to get about 70cm high for a standard desk height. Then drill & bolt them into the underside of the worktop. But this is more complex so probably only tackle this if you feel confident in your DIY skills.
#2971
Your desk setup looks really nice. Where did you get the black Alex drawers? I didn't think Ikea sold them in the UK.
Thanks, the drawers are MICKE..
I got them because everyone else seems to use Alex and I wanted something different (I didn’t fit the castors).
I'm liking the look of those draws!
If only delivery wasn't so expensive (to get the worktop as well)
Thanks that's helpful. Does it last for a long time or do you have to redo it?
The oil will last for a few years at least, then just slap on another coat.
I would really recommend using it though, it would be madness not to.
Osmo is great I heartily agree with @caff, it is not sticky and as the surface wears you can easily retreat. If you use their wax oil it almost sets into the woods surface. I used it on the woodworking workbench I built at my last house, easily tough enough for a desk. In fact I look to my left and I have huge set of shelves Osmo'd and home made pew downstairs the surface still looks great after years of use.
It would probably be worth oiling if you bring food/drink with you, to your desk. It doesn't take much to accidentally knock a full glass over.
Always liked the idea of counter tops as a desk but the decently priced / commonly available ones are usually pretty shallow in comparison to a normal desk.
We have two Alex units with a kitchen worktop on top.
We oiled it at the beginning, and glad we did because it felt a bit scratchy when it first arrived. That has lasted ~6 years with no maintenance required.
I need to build a couple of desk for my office as my cheap IKEA desk is falling apart. Has anyone got links to reasonably priced solid wood worktops with a decent depth?
I built a desk out of a butchers block worktop and its been great. Its basically a desk for life as its not going to wear away at the edges like chipboard will and if it does end up looking tatty after a few years you can just clean it and give it another coat of oil.
Another vote for Osmo oil. I went for the Acacia tinted worktop oil and it gave the oak a nice warm tone. Many recommend Danish oil, but personally I dont like the sheen, or the fact it turns the wood yellow. It also smells several times worse, takes longer to dry, doesn't protect as well and needs more coats. Osmo costs more, but its worth it IMO.
I use food grade mineral oil on my chopping boards if that's any help.
Zero stickyness but you do have to allow about 24hrs for it to sink into the wood.
