Hi - as title. I need a new case to fit longer graphics cards & the water cooling option is a +. Thanks
I have one and I doubt you will get a graphics card that is longer than the width of a motherboard in there.
Dang that literally kills it for me then was considering grabbing that case....
Its important to have plenty space in front of the card with good air going over it imo....
Looks like back to the massive Lian Li cases then![]()
Can I ask were u able to remove the hdd cage completly?
Surely this would allow tons more space for long graphic cards....
I was still considering this case and simply mounting my hdds in the top 5.25 bays with silent hdd boxes.
Yes it will come out completely. I took mine out to turn it round. You would have room then. I noticed in other threads your comments about aluminium resonating , that's something I have not come accross with this case due to the way the sides are constructed. The door is also a solid fit the way the catch holds it when shut. I am quite anal when it comes to noise and the PC I have in this case is very quiet even with 6 hard drives.
