NathanE said:No point using software like this unless you live in a country that actively pursues P2P users, such as the USA.
Surely this is irrelevant. I imagine they set up some torrent software and try and download an illegal file and take a look at the IPs they are downloading from, of these investigate the highest bandwidth connections.electric ant said:If you enable Protocol encryption (or something similar depending on torrent program), your data will be encrypted anyway.
|Ric| said:Surely this is irrelevant. I imagine they set up some torrent software and try and download an illegal file and take a look at the IPs they are downloading from, of these investigate the highest bandwidth connections.
Even if the protocol is encrypted surely the torrent program makes a direct connection with the pc so the IP can still be found. You would need a third party sat in the middle to hide your IP for you.
I do this in both eMule and µTorrent.electric ant said:If you enable Protocol encryption (or something similar depending on torrent program), your data will be encrypted anyway.
basmic said:I do this in both eMule and µTorrent.
I am behind a Linksys router, with Sygate firewall and NOD32, and PeerGuardian 2 loaded. So I hope I'm pretty safe.![]()
Believe it or not, I see Sygate as my weak point, because it is no longer being updated.JonRohan said:You preparing for WW3 mate.![]()
Let me put it another way - nobody has knocked at my door or sent me a letter about my file sharing activities, out of nearly 7 years.IAmATeaf said:Does PG2 actually protect you then?
Neither has this happened to me and I don't use anything like PeerGuardian or a firewall.basmic said:Let me put it another way - nobody has knocked at my door or sent me a letter about my file sharing activities, out of nearly 7 years.![]()
I'd rather wear a condom, than bareback the internet.Mark M said:Let me put it another way too...no one has knocked on my door in over a decade of filesharing without using any programs like this![]()
basmic said:I'd rather wear a condom, than bareback the internet.![]()
