Anyway to check if a CPU is throttling in Vista?
multisensor gadget bar tool which links into everest (which can do it on its own) - I use it to keep a check on clock speed, sys and cpu temps
Sometimes it’s not obvious. If performance suddenly drops how can you be sure it’s due to throttling and not some other bug or problem? A program will confirm throttling as the problem.
Thanks downloading everest now.
EDIT: My current motherboard sensors are way out so I cannot judge if the temp is safe or not.
