- 26 Dec 2009
- North
Not sure where to post, so GD it is.
As above I need more Molex connections to power GPU's, yes molex to power GPUs.
Problem is I bought an EVGA 650W Gold PSU, it has split 12v rails. Using the molex connections on it simply doesn't provide enough amps to power 6x 750 Ti's on powered risers. (60w each) Most amps are reserved for the PCI-e connectors.
So what I need to do is convert the 4 x PCI-e power cables to molex if that is possible? anyone know of any adapters?
Second option is to return PSU and buy something like a seasonic 650w Gold which has a single 12V rail and should be able to power all off molex.
Also a bit worried about melting the molex connections since they are not made to power GPU's. They are only 60w cards, will it be OK?
