Firstly you'll find it right here of course ocuk never seem to let us down:
Seagate Barracuda 7200.10 750GB ST3750640AS SATA-II 16MB Cache - OEM (HD-077-SE)
With up to 750GB of pure digital storage in a single drive, the Barracuda 7200.10 is the largest, most reliable disc drive around. New perpendicular recording technology supports vertically stored data bits, enabling increased areal density—and dependability—for workstations and performance PCs. After more than ten years of research, perpendicular recording is now a proven technology. It increases capacity and dependability by storing data vertically, rather than horizontally. And vertically stored data bits mean increased data density—and more gigabytes per platter.
- Capacity: 750 GB
- Speed: 7200 rpm
- Interface: Serial ATA
- Cache: 16MB
- 5 year manufacturer''s warranty
- Direct warranty and RMA service available here.
Recommended: Akasa Serial ATA Cables. Available in a large range of different colours and designs they keep your case tidy and improve DATA integrity.
Full Specification
Price: £252.95 (£297.22 Including VAT at 17.5%)
dont like that idea either, keep thinking though.... work with what we got, 2 holes in the side with the cpu you sitting dead center of both, perfectly designed for a baby OC machine, hexhaust system just need to be changed. We do have a bay which you could give up to a resivour but was thinking maybe a PCI sized resivour perfect suppourt...Better fan but still quiet silent beast me thinks, so youd never even know how hungry she really is....
Heat sink for Ati chip???
Do You have the D4 TV-OUT Connector cable installed on thhe machine, It is an optional feature?
Zalman ZM-2HC2 Silent Hard Disk Heatpipe Cooler on
http://www.overclockers.co.uk/acatalog/Online_Catalogue_Zalman_398.html something to use if decided to keep the 2nd hd option.
or
Akasa Hard Disk Cooler
http://www.overclockers.co.uk/acatalog/Online_Catalogue_Akasa_396.html
anyone tried this one?
With the db if one fan makes 28db of noise and another 32db, do you add them to get a total or does the loudest sound stand.
