- 1 Dec 2015
Why is the vrm even more beefy than the 9900k motherboards? AMD keeps saying 105w for 3900x, so motherboard manufacturers build it for 300w+ I’m confused
TDP isn't quite what Vendors state it is.
Intel is the worst ! Their 9900k TDP is stated at BASE clock speed , let alone boost of overclock.
AMD is at Single Core Boost - least they actually state TDP for boost speeds but this isn't all cores running at their best by default .
Overclock all 16 cores... Your power will run high !
A lot of people think with node shrinks, power drops by double meaning if you overclock it, should still draw half the power, this is wrong, once you start pushing overclocks, power jumps greatly !
These boards are designed to handle AVX loads at 24/7 .
If you want gaming, Gigabyte Gaming X
