Aorus GTX 1080 Ti - Won't Downclock
13 Apr 2011
Afternoon everyone,
I've just upgraded to a 1080 Ti from a 980 Ti and also paired it with a new monitor Acer Predator XB271HK (4K). I'm now having issues where the GPU wont downclock from full speed.
Some background information on the setup - I have the Predator set as my primary monitor with 2 additional monitors ether side both of which are 1080p.
The Predator and one of the 1080p monitors are connected using DP and DP to HDMI. The other is connected with HDMI.
I've had a look around on here and on Google and there are many people with similar issues, but i've not been able to find anyone with my monitor setup, to relate too.
I have followed steps to try and resolve the problem as I've been going along but nothing has worked. I've tried checking in the Nvidia control panel for "Power Management Mode" this is set to optimal power as has been from the get go. Tried changing the options but no luck there.
If i disable both my 1080p monitors the GPU downclocks instantly.
However if I disable just one of the monitors the GPU downclocks and stays there for the most part.
Is there anyone that can weigh in with similar issues? Or a way of fixing the above you've come across?
I've read from various sources it could be related to the 2D clocks not being able to handle all the resolution? But this just seems to be thrown around, and no actual proof.
Some images linked below showing the GPU behaviour.
All monitors enabled - https://imgur.com/a/fgDVA
One monitor disabled - https://imgur.com/a/h6YWm
Cheers,
Richard
It's standard that the memory clock stays boosted if you have two monitors plugged in, at least if one is 144 hz (I have no experience with 4k monitor).
Just for clarification is it the mem clock or core clock (or both?) not downclocking?
As a work around I use my IGPU to plug my second screen in with.
Thats where i'm a little lost you see, before the upgrade I had 3 1080p monitors running, and no issues with downclock :confused:
It's both the memory and the core clock that stay boosted.
Hmm thats an option to consider, should it come to that. Hopefully not though.
Hopefully someone with a similar monitor setup chimes in.
You can also try use a program called "Nvidia inspector" there is an option on the "show overclocking" tab which lets you adjust the power saving options for multiple monitor setups. I've not personally used it, but remember it was suggested to someone when investigating about the 144 hz and mem clock not downclocking.
I've had a look at the program you mentioned above. It works to a degree, but it appears as it forces a power state on the GPU it was causing the screen to flicker when a GPU intensive program was requesting more power but not getting it. There is a few settings to play with so i'll keep looking at this one, until like you said someone might hopefully chime in.
