Aorus Liquid cooler
Hi there,
I have just ordered the AORUS Liquid Cooler 360.
I have read on your website that is support 1200 CPU socket - https://www.gigabyte.com/uk/Thermal-Solution/AORUS-LIQUID-COOLER-360/sp#sp
However on the box and within the instruction manual there is no description or mention about the the 1200 socket.
Is anyone able to help if this will support the intel 1200 CPU socket before I try and fit this?
Thanks!!
I believe the 1200 and 115x socket is identical so you can follow the 115x instructions and will be fine.
